Einleitung
This guide will show how to safely remove the hard drive from the NoteMagix M10 A82 netbook.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Place the notebook on the table, with the battery facing away from you. Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Maintain both left and right switches in the "unlock" position. Use your forefingers to push the battery out of the computer.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD". Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  5. Lift the HDD plate off of the back to reveal the hard drive.
    • Lift the HDD plate off of the back to reveal the hard drive.
  6. Use the spudger to push the area above the connector on the hard drive to the right. Lift the hard drive gently from the computer with the spudger.
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
Abschluss
Sam Middleton
401 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Fall 2013 Mitglied von Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 191
