Einleitung
This guide is designed to provide you with simple steps to remove the back cover of the Verizon Ellipsis 10 to access the internal hardware.
Was du brauchst
Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
Once all the clips are undone, the back panel should come off with little effort.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
