Zum Hauptinhalt wechseln
Verizon Ellipsis 10 Battery Replacement
Was du brauchst
  1. Verizon Ellipsis 10 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Battery Replacement: Schritt 2, Bild 1 von 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Battery Replacement: Schritt 3, Bild 1 von 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Battery Replacement: Schritt 4, Bild 1 von 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Battery Replacement: Schritt 7, Bild 1 von 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Battery Replacement: Schritt 8, Bild 1 von 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Battery Replacement: Schritt 9, Bild 1 von 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
Abschluss
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Has anyone found a source for these batteries?
brianmjones - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,865
