Einleitung
This guide is designed to provide you with simple steps to remove and replace the Verizon Ellipsis 10 Motherboard.
Was du brauchst
Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
Once all the clips are undone, the back panel should come off with little effort.
Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
Unplug the battery power connector by sliding the white plastic plug down away from the board.
The battery should be free to come out of the device. Make sure not to bend or damage the battery.
Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
The module should come up with a little resistance.
Remove the non-conductive tape covering the camera ribbon cable.
You may need to remove the white antenna cable to remove the tape.
Peel up the ribbon cable carefully as it is glued to the device.
After having peeled up the cable, the cameras should be free to come out of the device.
Once all screws are removed, the motherboard should easily come off the device without any resistance.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
