Einleitung
This guide illustrates how to correctly replace the front facing camera on a Verizon Ellipsis 7. This is vital to preserve the device's ability to take pictures from the front. This guide will require extra precautions, as it includes removing the main motherboard. If performed incorrectly, the actions in this guide could break your device.
Was du brauchst
Hold down the power button until the screen goes black to turn off the device.
Remove the SIM card from the device to prevent damage.
To remove the SIM card, open the SIM card cover on the side of the device.
Push SIM card in and pull it out after hearing a click.
Take off the back panel.
Pry open the back cover carefully with a plastic opening tool.
Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
Remove the charging (micro-USB) port.
Unscrew the indicated screws using the Phillips #00 screwdriver.
Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
Remove the charging port board from the phone using tweezers.
Place the replacement charging port into the phone.
Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
Using tweezers carefully lift the connector up to disconnect it from the motherboard.
Using tweezers carefully pull the speakers up and out of device.
Use tweezers to carefully disconnect the power cable bundle from the motherboard.
Disconnect the two ZIF connectors that are connected to the motherboard with the spudger. Lift up the metal part of the connector and pull it off of its port
Once disconnected from the port, pull the metal part away from its connector carefully with the tweezers.
When all the connectors have been disconnected, you can gently lift the motherboard from the device.
Make sure the press lift connector is disconnected using the spudger, then carefully flip the motherboard over.
Disconnect the camera in the middle of the board using tweezers.
Eine weitere Person hat diese Anleitung absolviert.
