Zum Hauptinhalt wechseln
Einleitung
What you can expect from this guide is a step by step process on how to remove the plastic case on a Verizon Ellipsis Jetpack MHS800L.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the SIM card, that is located on top of the Jetpack. Remove the SIM card, that is located on top of the Jetpack. Remove the SIM card, that is located on top of the Jetpack.
    • Remove the SIM card, that is located on top of the Jetpack.
  2. With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device. Under the rubber circle, remove the 1.25 mm screw using a Philips #00 screwdriver. You may need to peel back a piece of double sided tape covering the screw hole.
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Philips #00 screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Remove three 1.25 mm screws.
    • Remove three 1.25 mm screws.
  4. Use a plastic opening tool at the seams and pry open the case.
    • Use a plastic opening tool at the seams and pry open the case.
  5. Once the cover is off, this is what your device will look like.
    • Once the cover is off, this is what your device will look like.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
IUPUI, Team 3-3, Baechle Spring 2016 Mitglied von IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 448
