Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
To replace the refresh button, you will need to open the router's outer casings. This replacement is simple and will not take much time to complete.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the device so that the bottom is facing up.
    • Flip the device so that the bottom is facing up.
  2. Insert the plastic-opening tool under the silver labeled casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  5. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  6. Locate the refresh button.
    • Locate the refresh button.
  7. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
    • Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
Abschluss
Jeffrey Fox
347 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 274
