Einleitung
Make sure you have followed the prerequisite guide of removing the battery before proceeding with this guide.
Was du brauchst
Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
Carefully remove the battery from the phone by prying the battery from the top.
Then use the plastic opening tool to remove the motherboard from the front half of the phone.
Next you will peel off the keypad after the motherboard is removed.
Lastly insert the new keypad.
To reassemble your device follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
