Zum Hauptinhalt wechseln
Verizon Wireless CDM 7075 Screen Replacement
Was du brauchst
  1. Verizon Wireless CDM 7075 Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Verizon Wireless CDM 7075 Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Verizon Wireless CDM 7075 Screen Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the battery from the phone by prying the battery from the top.
  3. Verizon Wireless CDM 7075 Screen Replacement, Screen: Schritt 3, Bild 1 von 1
    • Remove the rubber plugs from the screw holes around the screen with the opening tool.
  4. Verizon Wireless CDM 7075 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the four screws from around the phone's screen with a Phillips screwdriver.
  5. Verizon Wireless CDM 7075 Screen Replacement: Schritt 5, Bild 1 von 1
    • Pry the top cover off the phone with a plastic opening tool.
  6. Verizon Wireless CDM 7075 Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the screen assembly from the phone.
  7. Verizon Wireless CDM 7075 Screen Replacement: Schritt 7, Bild 1 von 1
    • Pry the circuit board off of the screen with the opening tool.
Abschluss
Corey Ryman
255 Reputation
4 Anleitungen geschrieben
James Madison, Team 2-4, Allen Fall 2011 Mitglied von James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 16
Insgesamt: 1,106
