Einleitung
The O2 and Air/Heliox filters are accessible from the rear panel of the ventilator. According to the service manual, the filters should be inspected and replaced as required.
PLEASE NOTE: This repair guide was developed by a student iFixit team based on Viasys/CareFusion's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Viasys or CareFusion.
Replacing these gas filters is discussed in service manual revision D:
- Chapter 8: Preventative Maintenance, Pg 163-164
Use the filter removal tool to unscrew the two filter covers.
Use the needle nosed pliers to grab the filter and pull straight out of the filter port.
Repeat for the second filter.
Using the needle nosed pliers, grab a new filter and slide it into the port so it is correctly aligned.
Align the filter cover with the filter inside the port and screw back on.
Ein weiterer Nutzer hat diese Anleitung absolviert.
