Zum Hauptinhalt wechseln
Vicks FilterFree Plus Ultrasonic Mist Maker Replacement
Was du brauchst
  1. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Tank Cap: Schritt 1, Bild 1 von 1
    • Ensure the device is clear of water before disassembling.
    • Orient the device so the nozzle is facing the ceiling.
    • Twist off the primary water holding cap.
  2. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 2, Bild 1 von 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 2, Bild 2 von 2
    • Place the device upside down so that the tank cap is facing you.
    • Use your hands to twist the tank cap and remove it from the device.
  3. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Ultrasonic Mist Maker: Schritt 3, Bild 1 von 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Ultrasonic Mist Maker: Schritt 3, Bild 2 von 2
    • Remove the three screws from the base of the device using a T20 Torx screwdriver.
    • Remove the base of the humidifier to access the components.
  4. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 4, Bild 1 von 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
  5. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 5, Bild 1 von 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 5, Bild 2 von 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 5, Bild 3 von 3
    • Remove the square heat shield by unscrewing the two screws using a Phillips #1 screwdriver.
    • Unclip the mist maker power cord.
  6. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 6, Bild 1 von 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 6, Bild 2 von 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: Schritt 6, Bild 3 von 3
    • Remove the triangle shaped heat shield by unscrewing the three screws using a Phillips #1 screwdriver.
    • Take note of the mist maker's orientation for reassembly.
    • Remove the mist maker from the device.
Abschluss
UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 Mitglied von UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 401
