Einleitung
If your humidifier is not producing any mist, then there may be a problem with the ultrasonic mist maker. If the mist maker is malfunctioning, it will need to be replaced.
Was du brauchst
Orient the device so the nozzle is facing the ceiling.
Twist off the primary water holding cap.
Place the device upside down so that the tank cap is facing you.
Use your hands to twist the tank cap and remove it from the device.
Remove the three screws from the base of the device using a T20 Torx screwdriver.
Remove the base of the humidifier to access the components.
Gently remove the inner shield for the primary board to access the wiring for the humidifier.
Remove the square heat shield by unscrewing the two screws using a Phillips #1 screwdriver.
Unclip the mist maker power cord.
Remove the triangle shaped heat shield by unscrewing the three screws using a Phillips #1 screwdriver.
Remove the mist maker from the device.
