Einleitung
Use this guide to remove the belt that moves the Visioneer OneTouch 7400 USB sensor bar for repair or replacement.
Was du brauchst
On the bottom of the scanner, remove the screw at the top left side.
Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
Remove the screw beneath the foot-pad.
Rotate the scanner so the screw hole is located on the top left hand side.
Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
Gently pry the two casements apart beginning above the screw hole and working your way around.
With the sensor bar turned upside down, remove the screw in the middle of the bar.
Lift off the metal plate if it does not come away with the screw.
