Zum Hauptinhalt wechseln
Visual Land Prestige 10 Back Case Replacement
Was du brauchst
    1. Visual Land Prestige 10 Back Case Replacement, Back Case: Schritt 1, Bild 1 von 3 Visual Land Prestige 10 Back Case Replacement, Back Case: Schritt 1, Bild 2 von 3 Visual Land Prestige 10 Back Case Replacement, Back Case: Schritt 1, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      Magnetic Project Mat
      $19.95
      • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
      • All screws throughout this guide are the same 3mm size.
      Frag FixBot
      Kommentar hinzufügen
    2. Visual Land Prestige 10 Back Case Replacement: Schritt 2, Bild 1 von 3 Visual Land Prestige 10 Back Case Replacement: Schritt 2, Bild 2 von 3 Visual Land Prestige 10 Back Case Replacement: Schritt 2, Bild 3 von 3
      • Using the spudger, create a small opening to be used to open the back case.
      • While holding the case open, insert the plastic opening tool to get a larger opening.
      • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
      Frag FixBot
    3. Visual Land Prestige 10 Back Case Replacement: Schritt 3, Bild 1 von 3 Visual Land Prestige 10 Back Case Replacement: Schritt 3, Bild 2 von 3 Visual Land Prestige 10 Back Case Replacement: Schritt 3, Bild 3 von 3
      • now that the case is open, carefully remove the speakers and set aside.
      Frag FixBot
    4. Visual Land Prestige 10 Back Case Replacement: Schritt 4, Bild 1 von 2 Visual Land Prestige 10 Back Case Replacement: Schritt 4, Bild 2 von 2
      • Gently remove the speakers from the back case with tweezers and set the case aside.
      Frag FixBot
Abschluss
1 Kommentar zur Anleitung
Ok but where to I go to buy the replacement for the screen? This is directing us to take apart and reassemble the tablet, but not where to buy or get a new screen.
Jordyn Glenn - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 1,788
