Zum Hauptinhalt wechseln
Visual Land Prestige 10 LCD Display Replacement
Was du brauchst
  1. Visual Land Prestige 10 LCD Display Replacement, Back Case: Schritt 1, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement, Back Case: Schritt 1, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement, Back Case: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 LCD Display Replacement: Schritt 2, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 2, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 2, Bild 3 von 3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 LCD Display Replacement: Schritt 3, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 3, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 3, Bild 3 von 3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 LCD Display Replacement: Schritt 4, Bild 1 von 2 Visual Land Prestige 10 LCD Display Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 LCD Display Replacement, Front Facing Camera: Schritt 5, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement, Front Facing Camera: Schritt 5, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement, Front Facing Camera: Schritt 5, Bild 3 von 3
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  6. Visual Land Prestige 10 LCD Display Replacement, Battery: Schritt 6, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement, Battery: Schritt 6, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement, Battery: Schritt 6, Bild 3 von 3
    • Remove yellow tape from surrounding components.
  7. Visual Land Prestige 10 LCD Display Replacement: Schritt 7, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 7, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 7, Bild 3 von 3
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  8. Visual Land Prestige 10 LCD Display Replacement: Schritt 8, Bild 1 von 1
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  9. Visual Land Prestige 10 LCD Display Replacement, Motherboard: Schritt 9, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement, Motherboard: Schritt 9, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement, Motherboard: Schritt 9, Bild 3 von 3
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  10. Visual Land Prestige 10 LCD Display Replacement: Schritt 10, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 10, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement: Schritt 10, Bild 3 von 3
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  11. Visual Land Prestige 10 LCD Display Replacement: Schritt 11, Bild 1 von 2 Visual Land Prestige 10 LCD Display Replacement: Schritt 11, Bild 2 von 2
    • Gently lift up the WiFi antenna and set aside.
  12. Visual Land Prestige 10 LCD Display Replacement: Schritt 12, Bild 1 von 2 Visual Land Prestige 10 LCD Display Replacement: Schritt 12, Bild 2 von 2
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  13. Visual Land Prestige 10 LCD Display Replacement: Schritt 13, Bild 1 von 2 Visual Land Prestige 10 LCD Display Replacement: Schritt 13, Bild 2 von 2
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
  14. Visual Land Prestige 10 LCD Display Replacement, LCD Display: Schritt 14, Bild 1 von 3 Visual Land Prestige 10 LCD Display Replacement, LCD Display: Schritt 14, Bild 2 von 3 Visual Land Prestige 10 LCD Display Replacement, LCD Display: Schritt 14, Bild 3 von 3
    • Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
    • Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
    • Set aside the LCD Assembly.
    • The LCD display and backlight are separated from one another. Be sure to remember how they are aligned when putting the device back together.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 1,933
