Einleitung
If your device's front screen is broken or cracked, this guide will show you how to replace it.
Was du brauchst
Remove the two 8mm Phillips Head screws located at the bottom of your device.
Insert the spudger between the two pieces of the case around the media ports and pry them apart.
Finish unsnapping each plastic piece holding the device together along the bottom.
Move the spudger down the rest of the case, separating each side, and finally the top.
Pull the back off and place it to the side.
Remove the tape holding the motherboard, wires, and connecters in place.
Unclip the three connectors by gently pulling the rear panel up and away from the motherboard.
Pull out each of the gold connections.
Remove the seven 4mm Phillips Head screws that hold the touchscreen panel and motherboard together.
Gently flip over the motherboard and begin to use the spudger to pry away the touchscreen panel from the front screen.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
