Zum Hauptinhalt wechseln
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
Was du brauchst
  1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: Schritt 1, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: Schritt 1, Bild 2 von 2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 2, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 2, Bild 2 von 2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 3, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 3, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 3, Bild 3 von 3
    • Wedge a curved metal spudger under the speaker in order to remove it.
    • The speaker is held in place by an adhesive and can be difficult to remove.
  4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 4, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 4, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 5, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 5, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 6, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift and remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 7, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 8, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 8, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 9, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 9, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 9, Bild 3 von 3
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 10, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 10, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
  11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 11, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 11, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 11, Bild 3 von 3
  12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 12, Bild 1 von 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 12, Bild 2 von 2
  13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 13, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 13, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 13, Bild 3 von 3
  14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 14, Bild 1 von 1
    • Safely remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 15, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 15, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 15, Bild 3 von 3
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 16, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 16, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 16, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 17, Bild 1 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 17, Bild 2 von 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 17, Bild 3 von 3
    • Wedge a metal spudger underneath the LCD screen to remove it.
  18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: Schritt 18, Bild 1 von 1
    • Replace the front screen to replace the digitizer.
Abschluss
UC Davis, Team 2-1, Oliver Fall 2016 Mitglied von UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 37
Insgesamt: 713
