Einleitung
This guide will show you how to remove the back panel to get to the components inside the tablet.
Was du brauchst
Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
