Zum Hauptinhalt wechseln
Vivitar DVR 781HD Front Case Replacement
Was du brauchst
  1. Vivitar DVR 781HD Front Case Replacement, Front Case: Schritt 1, Bild 1 von 3 Vivitar DVR 781HD Front Case Replacement, Front Case: Schritt 1, Bild 2 von 3 Vivitar DVR 781HD Front Case Replacement, Front Case: Schritt 1, Bild 3 von 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Front Case Replacement: Schritt 2, Bild 1 von 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Front Case Replacement: Schritt 3, Bild 1 von 3 Vivitar DVR 781HD Front Case Replacement: Schritt 3, Bild 2 von 3 Vivitar DVR 781HD Front Case Replacement: Schritt 3, Bild 3 von 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
Abschluss
Jordan Baum
355 Reputation
2 Anleitungen geschrieben
IUPUI, Team 54-6, Wilson Spring 2016 Mitglied von IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 287
