Zum Hauptinhalt wechseln
Vivitar DVR 781HD Motherboard Replacement
Was du brauchst
  1. Vivitar DVR 781HD Motherboard Replacement, Front Case: Schritt 1, Bild 1 von 3 Vivitar DVR 781HD Motherboard Replacement, Front Case: Schritt 1, Bild 2 von 3 Vivitar DVR 781HD Motherboard Replacement, Front Case: Schritt 1, Bild 3 von 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Motherboard Replacement: Schritt 3, Bild 1 von 3 Vivitar DVR 781HD Motherboard Replacement: Schritt 3, Bild 2 von 3 Vivitar DVR 781HD Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Vivitar DVR 781HD Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the motherboard, handling it by the edges.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team 54-6, Wilson Spring 2016 Mitglied von IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - Antwort
How do you get a motherboard?
Rdam Russell - Antwort
Where do we get one?
bikerbarbie29 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,421
