Einleitung
You will need a set of tweezers, a Phillips #00 screwdriver and a Phillips #000 screwdriver to replace your camera's lens.
Was du brauchst
Use a Phillips #00 screwdriver to remove the 3 mm screws at the sides of the camera.
Separate the front piece of the camera from the back, revealing the motherboard.
Use a Phillips #000 screwdriver to remove the two 2.3 mm screws that surround the lens.
Remove the two silver plates using tweezers.
