Zum Hauptinhalt wechseln
Vivitar Vivicam T027 Screen Replacement
Was du brauchst
  1. Vivitar Vivicam T027 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Vivitar Vivicam T027 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: Schritt 3, Bild 1 von 2 Vivitar Vivicam T027 Screen Replacement: Schritt 3, Bild 2 von 2
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: Schritt 7, Bild 1 von 2 Vivitar Vivicam T027 Screen Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Marist, Team 15-13, Laflen Spring 2015 Mitglied von Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Mitglieder
3 Anleitungen geschrieben
2 Kommentare
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Antwort
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 790
