Einleitung
If you are experiencing problems with your device's front or rear camera, this guide will help you to remove and replace the faulty part. Both cameras are connected and are removed simultaneously.
Was du brauchst
With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
Fast fertig!
Abschluss
