Zum Hauptinhalt wechseln
Vivitar XO 7 Motherboard Replacement
Was du brauchst
  1. Vivitar XO 7 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
  2. Vivitar XO 7 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • With the plastic opening tools, pry open the back cover.
  3. Vivitar XO 7 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover from the tablet.
  4. Vivitar XO 7 Motherboard Replacement, Battery: Schritt 4, Bild 1 von 2 Vivitar XO 7 Motherboard Replacement, Battery: Schritt 4, Bild 2 von 2
    • Peel off the black pieces of tape from the internal components.
  5. Vivitar XO 7 Motherboard Replacement: Schritt 5, Bild 1 von 2 Vivitar XO 7 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the battery from the tablet.
  6. Vivitar XO 7 Motherboard Replacement: Schritt 6, Bild 1 von 2 Vivitar XO 7 Motherboard Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
  7. Vivitar XO 7 Motherboard Replacement, Speaker: Schritt 7, Bild 1 von 1
    • Carefully remove the speaker from the metal plate with your hands.
  8. Vivitar XO 7 Motherboard Replacement: Schritt 8, Bild 1 von 2 Vivitar XO 7 Motherboard Replacement: Schritt 8, Bild 2 von 2
    Kaufen
    • With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
  9. Vivitar XO 7 Motherboard Replacement, Camera: Schritt 9, Bild 1 von 1
    • Peel off black tape that is holding the camera in place.
  10. Vivitar XO 7 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Carefully disconnect the ribbon cables from the motherboard.
  11. Vivitar XO 7 Motherboard Replacement: Schritt 11, Bild 1 von 2 Vivitar XO 7 Motherboard Replacement: Schritt 11, Bild 2 von 2
    Kaufen
    • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
  12. Vivitar XO 7 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
  13. Vivitar XO 7 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove four 4mm PH00 silver screws from the motherboard.
  14. Vivitar XO 7 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove two 2mm PH00 black screws from the motherboard.
  15. Vivitar XO 7 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove the silver cover from the motherboard.
  16. Vivitar XO 7 Motherboard Replacement: Schritt 16, Bild 1 von 2 Vivitar XO 7 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
Abschluss
James Lunn
116 Reputation
1 Anleitung geschrieben
USF Tampa, Team 11-1, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 937
