Einleitung
This guide will help users remove a broken Vizio CT15 display screen.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn the laptop off and remove all power cables. Remove the six Phillips #0 screws.
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Remove the six Phillips #0 screws.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop. Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  5. Using your fingers, unplug the wires. Using your fingers, unplug the wires. Using your fingers, unplug the wires.
    • Using your fingers, unplug the wires.
  6. Remove the six Phillips #0 screws. Disconnect the display from the laptop base by pulling the two apart from each other.
    • Disconnect the display from the laptop base by pulling the two apart from each other.
Abschluss
Brian Patino
234 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 103
