Einleitung
This guide will help users remove a broken Vizio CT15 display screen.
Was du brauchst
Turn the laptop off and remove all power cables.
Remove the six Phillips #0 screws.
Pull the back cover off.
Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
Disconnect the display from the laptop base by pulling the two apart from each other.
Fast fertig!
Abschluss
