Zum Hauptinhalt wechseln
Vizio CT15 Keyboard Replacement
Was du brauchst
  1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: Schritt 1, Bild 1 von 2 Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: Schritt 1, Bild 2 von 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Keyboard Replacement, Battery: Schritt 2, Bild 1 von 1
  3. Vizio CT15 Keyboard Replacement: Schritt 3, Bild 1 von 2 Vizio CT15 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Keyboard Replacement, Speakers: Schritt 4, Bild 1 von 2 Vizio CT15 Keyboard Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Keyboard Replacement: Schritt 5, Bild 1 von 2 Vizio CT15 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Keyboard Replacement: Schritt 6, Bild 1 von 3 Vizio CT15 Keyboard Replacement: Schritt 6, Bild 2 von 3 Vizio CT15 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Keyboard Replacement: Schritt 7, Bild 1 von 2 Vizio CT15 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
  8. Vizio CT15 Keyboard Replacement, CPU Fan: Schritt 8, Bild 1 von 2 Vizio CT15 Keyboard Replacement, CPU Fan: Schritt 8, Bild 2 von 2
    • Unplug the fan from the motherboard.
  9. Vizio CT15 Keyboard Replacement: Schritt 9, Bild 1 von 2 Vizio CT15 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the three Phillips #0 screws.
    • Pull the fan out to remove.
  10. Vizio CT15 Keyboard Replacement, Keyboard: Schritt 10, Bild 1 von 2 Vizio CT15 Keyboard Replacement, Keyboard: Schritt 10, Bild 2 von 2
    • Remove the four Philips #0 screws from the heatsink.
    • Pull up and out to remove the heatsink from the laptop.
  11. Vizio CT15 Keyboard Replacement: Schritt 11, Bild 1 von 2 Vizio CT15 Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the eight Phillips #0 screws from the motherboard.
    • Lift the motherboard up and out to remove it from the laptop.
  12. Vizio CT15 Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
  13. Vizio CT15 Keyboard Replacement: Schritt 13, Bild 1 von 3 Vizio CT15 Keyboard Replacement: Schritt 13, Bild 2 von 3 Vizio CT15 Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Use a metal spudger to carefully push the keyboard out of place.
    • Carefully flip the laptop over and pull the keyboard out.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
jalon
115 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 852
