Zum Hauptinhalt wechseln
Vizio CT15 Speaker Replacement
Was du brauchst
  1. Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: Schritt 1, Bild 1 von 2 Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: Schritt 1, Bild 2 von 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Speaker Replacement, Battery: Schritt 2, Bild 1 von 1
  3. Vizio CT15 Speaker Replacement: Schritt 3, Bild 1 von 2 Vizio CT15 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Speaker Replacement, Speakers: Schritt 4, Bild 1 von 2 Vizio CT15 Speaker Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Speaker Replacement: Schritt 5, Bild 1 von 2 Vizio CT15 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Speaker Replacement: Schritt 6, Bild 1 von 3 Vizio CT15 Speaker Replacement: Schritt 6, Bild 2 von 3 Vizio CT15 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Speaker Replacement: Schritt 7, Bild 1 von 2 Vizio CT15 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 374
