Einleitung
Over time, the back cover of the tablet remote may become worn out, or (in some cases) break. Here is a simple guide on how to renew it.
Was du brauchst
Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
