Zum Hauptinhalt wechseln
Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement
Was du brauchst
  1. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 2, Bild 1 von 1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 3, Bild 1 von 1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement, Haptic Motor: Schritt 4, Bild 1 von 1
    • After removing the back cover, you will be able to gain access to the speaker component.
  5. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 5, Bild 1 von 3 Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 5, Bild 2 von 3 Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 5, Bild 3 von 3
    • Pry the speaker up gently with the pointy end of the metal spudger.
  6. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 6, Bild 1 von 1
    • Pull the red and blue wires from the green circuit panel.
  7. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: Schritt 7, Bild 1 von 1
    • When reassembling, you will need to use the soldering iron to solder the red and blue wires back to the circuit board.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 175
