Zum Hauptinhalt wechseln
Vizio Tablet Micro USB Charging Port Replacement
Was du brauchst
  1. Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: Schritt 1, Bild 1 von 3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: Schritt 1, Bild 2 von 3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: Schritt 1, Bild 3 von 3
    • Begin by using the plastic opening tool to take off the back of the tablet.
    • Starting from the sides can make the process easier.
  2. Vizio Tablet Micro USB Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to disconnect the LCD screen.
  3. Vizio Tablet Micro USB Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Use the plastic opening tool to disconnect the camera.
  4. Vizio Tablet Micro USB Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to disconnect both of the volume buttons.
  5. Vizio Tablet Micro USB Charging Port Replacement: Schritt 5, Bild 1 von 2 Vizio Tablet Micro USB Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Then, remove all four of the 2.3 mm Phillips screws.
  6. Vizio Tablet Micro USB Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the circuit board from the platform.
  7. Vizio Tablet Micro USB Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the USB port from the circuit board.
  8. Vizio Tablet Micro USB Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Insert the new USB port onto the circuit board.
  9. Vizio Tablet Micro USB Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Lastly, fuse the USB port back onto the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jose
125 Reputation
1 Anleitung geschrieben
Ein Kommentar
Thank you it was very helpful simple and straight to the point
sirhc89chris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 932
