Einleitung
Hello! This guide will show you how to replace the digitizer on your Vizio VTAB1008.
Was du brauchst
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Look into the tablet for loose connectors.
Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
Remove the two brackets accompanying screws by lifting them up and away from the screen.
Separate the screen digitizer from the display screen, noting the placement of the quick disconnect ribbon cable.
