Einleitung
Hello! This guide will help you replace the Wi-Fi antenna in your Vizio VTAB1008.
Was du brauchst
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Look into the tablet for loose connectors.
Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
