Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons. Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Look into the tablet for loose connectors.
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Using the  blue spudger/prying tool remove antenna connectors by prying them up from the motherboard. Using the  blue spudger/prying tool remove antenna connectors by prying them up from the motherboard. Using the  blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
    • Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
  4. Remove connectors from the  back cover by gently prying. Connectors are glued down, but copper can be removed from the backing with light pulling. Connectors are glued down, but copper can be removed from the backing with light pulling.
    • Remove connectors from the back cover by gently prying.
    • Connectors are glued down, but copper can be removed from the backing with light pulling.
Abschluss
Gilberto Ambriz
540 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 78
