Zum Hauptinhalt wechseln
Volleyball Valve Replacement
Was du brauchst
  1. Volleyball Valve Replacement, Valve: Schritt 1, Bild 1 von 1
    • Bend a thin metal wire into a hook.
    • This is what we will be using to wiggle the air valve out.
  2. Volleyball Valve Replacement: Schritt 2, Bild 1 von 1
    • Insert the wire into the valve and use it to hook and pull out the valve as much as possible. .
    • This process might take awhile depending how broken the valve is.
  3. Volleyball Valve Replacement: Schritt 3, Bild 1 von 1
    • Once a piece of the valve is sticking out, use the needle nose pliers to pull out the valve.
  4. Volleyball Valve Replacement: Schritt 4, Bild 1 von 1
    • With your new valve, place it to the hole where the previous valve was, and use the screwdriver to push it in until it is flush with the surface of the ball.
  5. Volleyball Valve Replacement: Schritt 5, Bild 1 von 1
    • You are done! The volleyball valve has been replaced and should not let any air out.
Abschluss
Justin Nadela
121 Reputation
1 Anleitung geschrieben
York University, Team R-18, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-18, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG18
1 Mitglied
2 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thanks for this!!
Can you please let me know what valves to buy?
(my email address is sendtojfk@gmail.com)
Thanks!
Justin Kern - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 40
Letzte 30 Tage: 147
Insgesamt: 5,473
