Einleitung
This machine helps children understand that value of saving money for something that they hope to buy. Although useful, this machine has a tendency to make extremely loud noises when in use.
Was du brauchst
Unscrew the 6 phillips screws on the left and right side of the machine with a 603-3 IN. 1PT phillips screwdriver.
CAUTION: Use caution while opening the machine, wires will be attached to both sides. Place screws on the Magnetic Mat to avoid misplacing them.
The Zillionz ATM Machine Speaker is placed on the upper left of the machine. The speaker is a circular green shape with a thin purple cover holding the speaker in place. There will be two yellow wires connecting the speaker to the circuit board.
Using the ifixit screwdriver with phillips head J1, unscrew the two screws located on the ends of the purple piece covering the speaker. Place screws onto Magnetic Mat.
Place the sticky side of the felt pad directly in the center of the clear plastic covering on speaker. Place another felt pad directly on top of the felt pad that was just placed on the speaker.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
