Einleitung
If the fan blades of the Vornado 133 are dirty or become damaged, it may be necessary to remove them for cleaning or replacement. This guide will detail how to remove the front grill in order to access the blades, as well as how to remove and replace the blades themselves.
Was du brauchst
Once the screws are removed, turn the fan back over. Use your hands to pull the front grill cover off.
Turn the center nut on the blade shaft clockwise to remove the nut, then remove the blades.
