Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Remove the screw that secures the hard drive access panel to the base of the computer.
Insert a plastic scribe into the slot and lift up the access panel, then remove the panel from the computer.
Slide the hard drive toward the right side of the computer.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
