Zum Hauptinhalt wechseln
Vostro 1720 Memory Module Replacement
Was du brauchst
  1. Vostro 1720 Memory Module Replacement, Sliding the Latches: Schritt 1, Bild 1 von 1
    • Slide the battery lock latches into the unlocked position.
  2. Vostro 1720 Memory Module Replacement, Slide the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery toward the back of the computer to remove.
  3. Vostro 1720 Memory Module Replacement, Remove the Screws: Schritt 3, Bild 1 von 1
    • Remove the eight screws from the access panel.
    • Lift the edge of the access panel that is closest to the center of the computer.
  4. Vostro 1720 Memory Module Replacement, Remove the Access Panel: Schritt 5, Bild 1 von 1
    • Remove the access panel.
  5. Vostro 1720 Memory Module Replacement, Removing the Memory Module: Schritt 6, Bild 1 von 1
    • If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
  6. Vostro 1720 Memory Module Replacement, Sliding the Memory Module: Schritt 7, Bild 1 von 1
    • Slide the memory module out of the socket.
  7. Vostro 1720 Memory Module Replacement, Spreading apart the Clips: Schritt 8, Bild 1 von 1
    • If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  8. Vostro 1720 Memory Module Replacement, Sliding the Memory Module: Schritt 9, Bild 1 von 1
Ziellinie
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 70
