Einleitung
In this guide, we will be showing you how to remove and replace the Memory Modules.
Was du brauchst
Lift the edge of the access panel that is closest to the center of the computer.
If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
