Zum Hauptinhalt wechseln
Vtech InnoTab 3 Rear Panel Diassembly
Was du brauchst
  1. Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: Schritt 1, Bild 1 von 3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: Schritt 1, Bild 2 von 3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: Schritt 1, Bild 3 von 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech InnoTab 3 Rear Panel Diassembly: Schritt 2, Bild 1 von 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech InnoTab 3 Rear Panel Diassembly: Schritt 3, Bild 1 von 3 Vtech InnoTab 3 Rear Panel Diassembly: Schritt 3, Bild 2 von 3 Vtech InnoTab 3 Rear Panel Diassembly: Schritt 3, Bild 3 von 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech InnoTab 3 Rear Panel Diassembly: Schritt 4, Bild 1 von 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
Abschluss
Colorado Springs, Team 5-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,131
