Einleitung
Is the speaker malfunctioning on your child's tablet? Does it need to be replaced? This guide will walk you through replacing the speaker on the Vtech InnoTab 3S.
Was du brauchst
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
Using a nylon spudger, remove the five caps that hide the screws.
Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
Using a soldering iron, heat the connections securing the speakers to the motherboard of the device.
Remove the connections on the motherboard to detach the speaker.
Eine weitere Person hat diese Anleitung absolviert.
