Zum Hauptinhalt wechseln
Vtech Innotab 3 Speaker Replacement
Was du brauchst
  1. Vtech Innotab 3 Speaker Replacement, Rear Panel: Schritt 1, Bild 1 von 3 Vtech Innotab 3 Speaker Replacement, Rear Panel: Schritt 1, Bild 2 von 3 Vtech Innotab 3 Speaker Replacement, Rear Panel: Schritt 1, Bild 3 von 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
    Frag FixBot
    Kommentar hinzufügen
  2. Vtech Innotab 3 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
    Frag FixBot
  3. Vtech Innotab 3 Speaker Replacement: Schritt 3, Bild 1 von 3 Vtech Innotab 3 Speaker Replacement: Schritt 3, Bild 2 von 3 Vtech Innotab 3 Speaker Replacement: Schritt 3, Bild 3 von 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
    Frag FixBot
  4. Vtech Innotab 3 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
    Frag FixBot
  5. Vtech Innotab 3 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 3 Vtech Innotab 3 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 3 Vtech Innotab 3 Speaker Replacement, Speaker: Schritt 5, Bild 3 von 3
    • After you disassemble the device, put the back panel to the side and move your attention to the front piece.
    • Remove the four screws using a PH00 screwdriver.
    Frag FixBot
  6. Vtech Innotab 3 Speaker Replacement: Schritt 6, Bild 1 von 2 Vtech Innotab 3 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Using a nylon or metal spudger, lift the blue plastic piece upwards.
    • Keeping the plastic piece lifted, carefully pinch the edge of the speaker and remove it.
    • Be sure not to tug on the speaker too violently to prevent tearing a wiring from its solder.
    Frag FixBot
  7. Vtech Innotab 3 Speaker Replacement: Schritt 7, Bild 1 von 3 Vtech Innotab 3 Speaker Replacement: Schritt 7, Bild 2 von 3 Vtech Innotab 3 Speaker Replacement: Schritt 7, Bild 3 von 3
    Frag FixBot
Abschluss
Colorado Springs, Team 5-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 885
