Einleitung
Faulty batteries can often be the cause of a malfunctioning drum set. This guide is designed to show how to correctly replace the batteries in your drum set in order to restore power and proper function.
Was du brauchst
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
Fast fertig!
Abschluss
