Einleitung
A broken or cracked cymbal can be very hazardous to small children. Additionally, a damaged cymbal could prevent the drum set from working properly. This guide is designed to show how to correctly replace the green cymbal in order restore your drum set to a safe and functioning condition.
Was du brauchst
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
Use Phillips #2 screwdriver to loosen and remove the single 16 mm screw.
Using a Phillips #00 screwdriver, loosen and remove the three 12 mm screws located on the bottom of the green cymbal.
Eine weitere Person hat diese Anleitung absolviert.
