Einleitung
A broken or cracked drum head can be very hazardous to small children. Additionally, a damaged drum head could prevent the drum set from working properly. This guide is designed to show how to correctly replace the white drum head(s) in order restore your drum set to a safe and functioning condition.
Was du brauchst
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
To replace the white drum head on the cymbal side, use a Phillips #00 screwdriver to loosen and remove the two 8 mm screws.
To replace the white drum head on the side opposite of the cymbal, use a Phillips #00 screwdriver to loosen and remove the two 8 mm screws.
Using your hands, remove the orange rim and white drum head from the blue base.
