Zum Hauptinhalt wechseln
Vtech Kidizoom Smart Watch DX Faceplate Replacement
Was du brauchst
  1. Vtech Kidizoom Smart Watch DX Faceplate Replacement, Faceplate: Schritt 1, Bild 1 von 1
    • Flip the watch so that the screen faces upward.
  2. Vtech Kidizoom Smart Watch DX Faceplate Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to gently pry the edges of the faceplate away from the watch.
    • You may hear some popping sounds as you are removing the faceplate. This is normal.
  3. Vtech Kidizoom Smart Watch DX Faceplate Replacement: Schritt 3, Bild 1 von 1
    • Pull the faceplate fully apart from the watch.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 10-6, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Mitglieder
12 Anleitungen geschrieben
6 Kommentare
Where can I get a new faceplate???
Eileen Osborne - Antwort
Yes even I have same Question ..Where do I get this faceplate??
Manisha Divekar - Antwort
Did you get an answer on you question. I need a faceplate too
Please advise
michele - Antwort
that really helped
Bethel Befekadu - Antwort
Where can I get a replacement faceplate
cram66bum - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 6,003
