Zum Hauptinhalt wechseln
Vtech Touch and Swipe Baby Phone Power Switch Replacement
Was du brauchst
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: Schritt 1, Bild 1 von 2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
    Frag FixBot
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 2, Bild 1 von 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 2, Bild 2 von 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 2, Bild 3 von 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
    Frag FixBot
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 3, Bild 1 von 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 3, Bild 2 von 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 3, Bild 3 von 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
    Frag FixBot
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: Schritt 4, Bild 1 von 2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: Schritt 4, Bild 2 von 2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
    Frag FixBot
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 5, Bild 1 von 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 5, Bild 2 von 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: Schritt 5, Bild 3 von 3
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 2-4, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - Antwort Teilen
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 59
Insgesamt: 1,116
