Zum Hauptinhalt wechseln
VuPoint DC-ST210-VP Battery Door Cover Replacement
Was du brauchst
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: Schritt 1, Bild 1 von 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: Schritt 2, Bild 1 von 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: Schritt 2, Bild 2 von 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: Schritt 2, Bild 3 von 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: Schritt 3, Bild 1 von 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: Schritt 3, Bild 2 von 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: Schritt 4, Bild 1 von 1
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: Schritt 5, Bild 1 von 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: Schritt 5, Bild 2 von 2
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: Schritt 6, Bild 1 von 1
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Elise Brown
70 Reputation
2 Anleitungen geschrieben
Baylor, Team 8-15, Williams Fall 2014 Mitglied von Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 356
