Einleitung
If you need to replace a Brad Nailer Pressure Regulator Chamber Gasket, follow the steps outlined in this guide. For this guide, you will need a 4mm Allen wrench. The steps outlined are relatively easy to follow.
Was du brauchst
Using a 4mm Allen wrench, remove the 4 Allen screws, 44mm in length, from the yellow cap on the back of the brad nailer.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
